Discuss Supply Calculations help? in the UK Electrical Forum area at ElectriciansForums.net
E
energizedelec
iv been asked to install a supply to a house and im a bit rusty. can someone please walk me through the cable calculations?
supply is a protected by a 100a bs1361 fuse, cable will be swa installed direct in ground, cable length around 40 mtr.
thanks
ok so after applying diversity Ib = 91.5A and In=100A
so from table 4d4a multi-core armored 70'c refrence method D you get 99A for 25mm cable.
then volts drop mv/a/m = 1.75
so...
1.75 x 91.5A x 40 mtr /1000 to convert to volts = 6.405v
now if it was a final circuit not for lighting this would be ok (as it doesnt exceed 11.5v 5%). but its for a distribution circuit so if i was to then have other circuits running of it the volts drop would increase how do i account for this??
Reply to Supply Calculations help? in the UK Electrical Forum area at ElectriciansForums.net
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
Got an EV (Nissan Townstar EV) in my house, has a Zappi EV charger installed (by myself) and notified via ENA form to Scottish Power energy...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
