S
Spazz
Just a quick question - think I know the answer but want to check for 100%.
Is each cable in 16mm SWA the same size as 16mm tails?
The reason I ask is the job Im working on now, the home owner bought some SWA (was told it was 16mm) over 6 months ago, he wants me to run this for the supply for flats.
The Cable itself is the same diameter as 10mm
16mm armoured is the same CSA as 16mm tails. Sometimes tails seem to have a 'looser' stranding to swa and appear to be bigger at least to my eye, swa cores seems to be more tightly stranded almost appearing as one solid lump as opposed to being stranded, look at the inner of 16mm tails and 16mm T+E. Insulation is often thinner (especially xlpe) Suppose it comes down to brand as well.
I paired back the installation on both the tails and SWA Cable and they where clearly different.
The SWA cable has a diameter of 4mm (10mm CSA to my calculations)
What does it say on the cable sheathing?
there are no markings on the Cable that I can see - that was the first thing I checked for - hes had it for a minimum of 6 months maybe more. I will be talking to him tomorrow about it - just didn't want to look like a fool.
If there's no BASEC markings avoid it like the plauge. Don't be fooled by the apparent SCA, rolled and shaped condutors do look small.
Have a look at BASEC It may just put you well and truely off the stuff.
Or just compare one single strand from a known 16mm cable to that of the suspect cable, that can be done visually, or put a micrometer on a single strand and check.... Sounds like he's been sold 10mm for 16mm, either by accident/mistake or purposefully... lol!!
I had a customer do this to me a little while ago, he was buying the cable and was instructed to get 16mm for a sub main. But he called me saying the website says that 10mm SWA will carry 100A. I told him repeatedly to buy 16mm, what did he get? 10mm because its a lot cheaper and their website say it will do the job. Fine, I fused it right down accordingly.
Spazz,
drew35,
