Discuss SWA easy question in the Electrical Forum area at ElectriciansForums.net
Dizzy_Maskell
Guys not done SWA for ages now and forgot my sizes a bit
So cable already ran in just needs connecting both ends its 6mm 4 core and Earth. Question is what gland size do I need outdoor rated I'm guessing 20L. ?
Sent from my iPhone using Tapatalk
Cw20..Do you mean 4core or 5core as you say 4core and earth? Either way if you use a CW gland it will be a 20. the rough diameter of 6mm 4core is 18.7mm and 5core 20.5mm.
You are correct 20mm cw swa gland
4 core and Earth, never seen that animal, do you mean 5 core?
just get a 20L pack and a 20S pack. the one that doesn't fit can remain in your van stock. anyway, dizzy, when are we going to go for that pint?
Reply to SWA easy question in the Electrical Forum area at ElectriciansForums.net
