Discuss SWA gland? in the Commercial Electrical Advice area at ElectriciansForums.net
Found this at work, looks like they'd run out of SWA glands...
I remember using them in the 70's, Henley glands? used for cable with a spiral metal sheath which I haven't seen for years, don't know if it's still used?.
Glands still available and ive used them on occasion but agree with Tony in that im unsure the cable is produced anymore, seen loads on machinery but not any new.
Yes the old armour flex you can still get but special order I think and isn't cheap I think most people wouldn't even use the sheething and just use a compression gland but not great
Reply to SWA gland? in the Commercial Electrical Advice area at ElectriciansForums.net
I'm working on a system that has been installed incorrectly. It's a 3ph Hager board with 8 swa cables glanded into the bottom entry panel. The...
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
5K
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
