Testing would give you a good idea on the size of the cable but what about the integrity of the PVC ? I would not trust this cable now what your telling me about the fake BS numbers
Ask the guy to contact the seller and find out who made the cable, armed with this information contact basec and see what they have to say about it.
We only use Prysmian cable from Screwfix - normally cheaper than my wholesaler and I know its OK.
The guy has just sent me the eBay listing 370868736930, all looks correct and he had read me the BS numbers
Originally he was going to do it him self then decided to call me in, he all ready had the cable by this point, Going back for another look tomorrow, just seem a bit small on the pair to me but will strip some out and have a proper look.
I just pop back home and get my micro scales to check it then :driving:.
To much messing around just tell the customer you will supply the cable.
There’s no more accurate method. Just because you are unable to work accurately isn’t my fault, it’s yours.
Sorry I can’t work out the CSA so you’ll have to buy another drum of cable. That’s going to go down a bundle with any client.
Its not just the CSA under debate here though, its the standard of the cable as a whole and whether or not it has been manufactured correctly and according to standards.
Yes but you do still need a good set of scales or as the OP says a good tester to check the resistivity I'm just saying its a lot of messing around for such a small Job
I've had this in the past with 300mm and 400mm singles. The crimp lug for the 300 mm just about fitted the 400mm cable and the 400 mm crimp was not tight enough for 400mm cable.
When checked with the manufacturer his reply was the same as yours Lucien
Ive had the exact same problem!...doncaster cable it was...
