T
thekingiam
just starting a quote for a job putting a new supply for four bedsits above pub. the run has got to go up through pub behind fruit machine i recon about 25 mtrs but getting 35 in case now i know no rcd protection needed as swa but was thinking to cover my bottom by putting it in at supply what do you guys think?
I would out in a 100ma s type time delayed to cover myself and protect circuits with 30 ma within the flats. But that's just me I'm sure others will have different opinions.
i'd say keep thinking about that some more :-)
will the bedsit tenants have access to the pub mains 24 hrs a day to reset the rcd after one of them plugs in a duff hairdrier ?
very good point! although being called out every night to the pub may have it's advantages.
i think box in.
only a quick visit last night so couldn't measure acurately any cable left is mine so 35 mtrs it is
If the cable was mechanically protected you wouldn't need to and if your supply cables required rcd protection then a delayed type wouldn't comply with regulation.
My thoughts on this would be MICC ....yes the dreaded!!!!
But if he had 30ma within the flat he would require discrimination. And as it is mechanically protected and does not require the rcd protection would a time delayed still not comply? Why would you opt for micc over swa?
If your merely fitting it as extra protection that isn't required then yes it would comply but at extra cost and means you are less competitive when quoting .... if you want to win jobs in the real world you need to be competitive ... i mentioned Micc because it a fraction of the size in comparison to swa and csa for csa it can handle more current... his larger boxing he's worried about wouldn't be such an eyesore.
good grief its a pub not laurence lleweln bowens designer studio.
there will be all manner of nooks , crannys , store cupboards and service voids knocking about to get the cable in without chasing and without upfront rcd.
if you cant manage that then youve no business doing commercial work in the first place.
depends on what your kind of pub is Biff....
