pirate
Supporter
Some assistance please.
simple job really, 3-core 4mm SWA to be glanded into a box with a 20mm S gland, and piranha nut.
I'm not familiar with the Wiska brand, but as it gets a good name I thought I'd try a couple. Was looking at the 206, but frankly I get easily confused so maybe one of you might suggest the best box.
Thank you.
I think the whisker boxes are pre threaded to 20mm thus been plastic are not really suitable for swa earthing, the piranha nut simply will not fit, I would get a standard IP rated plastic box and gland as normal using the earth ring or piranha nut as required.
I have some Piranhas though...
maybe just go with a plain box, and try the Wiska range another time.
so many plain IP rated boxes to choose from, so that's maybe my easiest solution.
I thank you all for your input...much appreciated, and gratefully received. :)
I personally have not tried a piranha nut thingy , I usually just put the bangos on the inside kink them up and bolt together,,,,
Yer missin' out, mate. I wouldn't be seen without them, these days.
Just installed some pvc 32A 3 phase/N/E 5 pin sockets with isolators. They leave drilling and linking banjos in the shade.
Do they go bang. by the way?
pirate
Supporter
Glasgow
Electrical Enthusiast (Unqualified Hobbyist etc)
SWA/wiska box/piranha nuts
Thread Tags
pirate,
Lister1987,
