swa
Discuss swa in the Canada area at ElectriciansForums.net
benji
why are we still using armoured cables?they don't use them offshore and that a harsh enviroment,is it true only uk and one or two european countries use it.Give me a braided flexable cable any day,bending/glanding/terminating is a piece of cake compaired to swa.
yours benji
gotta be honest, i worked for years out in the field, putting in temporary installations run of gennys, i spent 5 years doing aircraft crashes, and lets be honest, thats a pretty harsh environment
it was braided all the way for me!!! that was for three phase, single phase, and 110V CTE supplies - and the cables werent buried either, i just used to nip and tuck them under the grass with a shovel
SWA is a bit of an overkill sometimes, seen people using it automatically every time they are wiring outside
lets start the revolution ! SWA aint needed especially in this day and age of rcd's
it'll never happen until there is european edict that this kow tow'ing goverment will kiss a**e to if it was down to these inbreeding politicians we'd never have decimilisation or metrification !!!
over paid ----ers, imagine how much they'd get paid for the amount they do in the real world .if a plc was run this inefficiently it'd be bankrupt
just a quick question, does the voltage on a tp+n system need to be the same between phases
well pretty much yeah, that what allows you to dispense with the neutral on three phase motor circuits
oh, and under the 17th, do we now have to call it single line and three line?:p
i thought so.just checked at main incomer and getting L1 to earth 250v, L2 to earth 220v, and L3 to earth 225v.
utility company says it is within limits
Reply to swa in the Canada area at ElectriciansForums.net
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
5K
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
An Invitation to Retired Electricians anywhere except the UK with Four Days a Month for a Niche Opportunity That Can Earn 15K a Year. There are...
I’m wavering a bit on this one. RCD then B10 breaker. 1.5 sq mm 3 core SWA. That runs underground in ducting, then up and feeds about 10 LED class...
I have a metal Hager sub CU, 10 way RCBO, installed in 2018 in an accessible attic space, this sub-CU being fed from another unit close to the...
6K
