Discuss Swapping from sz2301 to szm1801 valves in the Central Heating Systems area at ElectriciansForums.net
Hi,new to this forum. I'm swapping from sz2301 valves to Szm1801 valves to see if there any better as the spring return ones only last a couple if years before either the micro switch or the motor gives up. Is the wiring the same as it looks slightly different. The brown and blue wires for the motor look the same but it says the grey wire must go to a permanent live where as on the old ones I don't think it was.
Thanks,Bryan
Reply to Swapping from sz2301 to szm1801 valves in the Central Heating Systems area at ElectriciansForums.net
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
I had to wire in an extra 2 port valve today to protect a newly installed unvented cylinder (replacing the old gravity fed one) in a standard Y...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi, We are designing and building cooking gas bottles with electronics controlled valves. These are for kids camping chalets. Its purely a...
