W
wildgoose
Backbox Mounting Screw Replacement.
I've often come across stripped threads on metal backbox lugs which have been so badly abused, that the normal 3.5mm re-threader is useless because the hole is already too big. The only safe solution (electrically), is a replacement back box. This is time comsuming and can be cosmetically risky - especially if the backbox is set behind wall tiles!
Question:
Any of you know out there if they do bigger screws, which still fit and look ok in the moulding ? Would think 4mm or 4.5mm would do the trick but the heads must be very similar to the conventional 3.5mm screws.
Question:
