- Reaction score
- 8,940
It’s one of the few stipulations on mine too.If you tie helium balloons to yourself, then technically, you are not on the roof...
Must be considered quite risky for people to not insure you for it.
Discuss T.V aerial installation in the UK Electrical Forum area at ElectriciansForums.net
My insurance with Hiscox is quite specific and doesn't insure me to go onto roof to install an aerial.
And before you start, make sure it has a solid copper core, a copper foil, and a copper braid - there's plenty of stuff sold as "satellite" cable that I wouldn't use to hang the washing on.Leave it to the professionals but by all means run the coax. Don't use the cheap brown stuff, use type 100 satellite grade cable.
I agree, you certainly need at least 2 uhf aerial connections/cables from each point where there is a receiver, to a central point (loft?) -one in, one out, (if lucky enough to have a uhf output or with your technomate), but I'd add that to future-proof further, cat6 between receiver and other viewing points that don't have a sat receiver, but where you may want to view and control HD other than Freeview HD, would enable an HDMI to cat5/6 to HDMI (plus IR) at a later stage.This is just a suggestion. It may go beyond your immediate requirements but I have installed a TV distribution system in my home that allows for an number of further options. It does require two (or three to support satellite) coaxial cables to be installed to the main TV location.
We bought a house which already had Coaxial cables wired to each room but the main room was wired to a satellite dish. These cables were nit connected anywhere,
I had a Freeview TV aerial installed by a professional installation company (we are in a fringe area and needed a very good aerial)
I installed a video distribution system as shown in the diagram. This requires at least 2 coaxial cables to the main TV location. the optional third cable is for a second satellite feed. This enables me to play programmes stored on the PVR in any room with full use of the PVR remote control in each room.
The TV signal goes into the PVR (Humax) and then via the HDMI cable to a FreeView encoder that adds a new Freeview channel (800) that is added to the broadcast signal and which goes via the uplink cable to the video distribution amplifier. Each of the TVs has a "magic eye" that takes the Infra Red signal from the PVR remote and sends it back to the PVR via the "return channel" where it replicates the IR signal to the PVR. It does need a video diplexor to feed the main TV.
The encoder model shown is the only one I found that worked properly. There is an Edimax equivalent but the encoding delay was unacceptably long and this made the remote control unusable in the other rooms.
I have had this working perfectly since early January.
If you install the additional coaxial cable(s) now and choose a video amplifier with a return path then you can add the extra features later. The expensive item is the encoder. The other items add little to the cost.
To be fair, it's not the end of the world if a couple of cat6's aren't in safe zones!
I agree - but the BBB says otherwise.To be fair, it's not the end of the world if a couple of cat6's aren't in safe zones!
A little nonsense here, but generally good stuff. Firstly, there's no such thing as 'satellite cable'.
Reply to T.V aerial installation in the UK Electrical Forum area at ElectriciansForums.net
