R
Rauer
32mm heavy gauge pvc pipe from gable too shed , it will sag
Would also look horrendous!!
white pvc conduit with t&e inside to adaptable box at bottom of house will look very neat if house is white! I use black if house is normal brick, only looks good if dead straight and equal spaced saddled though!
Same as a metal box but the plastic is thicker so may mean not much room for extra nuts, use a piranha earth nut or the like to make it easier. Obviously you will need a fly lead from the gland as you will not be able to earth through the box!do swa gland to plastic as you would with metal box????
