Discuss Temperature probe with 110k ohm resistance! in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi all
I have an electric underfloor heating system in my bathroom with a Timeguard TPT88 controller:
(TPT88 - 24 Hour/7 Day Multi-Programmable Thermostat | Timeguard - http://www.timeguard.com/products/climate/thermolay-ufh-controllers/24hour-7-day-multi-programmable-thermostat)
The system as about 5 years old and the controller has died. However, getting a like for like replacement is not possible as Timeguard have discontinued the unit (the model still shows up on some websites/eBay, but is always 'out of stock').
Asking around, no one seems to stock a controller that is compatible with the resistance of the temp probe. Just wondered if anyone on here has experience of replacing a TPT88, and if so, with what? If that's not going to work, can I change the temperature probe without ripping up the floor?
Any advice much appreciated!
Ian
It will be a NTC probe probably, but it's still high resistance.
Edit...I see that you didn't measure that now clicking that link.
I'm prettier sure you have a NTC thermistor.
Maybe you can poke a new probe in a few inches with a blunt plastic pokey thing.
That was my 2nd best ever,chat-up line...you plagiarist ;)
Reply to Temperature probe with 110k ohm resistance! in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi all, I have a slightly mish-mash heating set up, in that downstairs I have wet underfloor heating with an individual thermostat per room, but...
Eh up :) Client (doing other work there) accidentally smashed up their underfloor heating controller in their kitchen. The only thing I've been...
Hello to everybody taking the time to read this post. I hope it is oK to post this here. I will start by introducing myself, I'm Martin from...
C
Sorry in advance for the long thread! Just want to make sure i provided as much detail as possible. We are currently building an extension and...
5K
