B
Baker1988
hi lads hope you enjoying ya friday night and not too drunk.
I have just finished a rewire on a communal area in a block of flats, all surface mounted with pir's and fluorescent/emergency lights.
I have been told today that i will be testing it on monday with my boss but i will be doing the testing while he watches, basically im not 100% sure about the dead testing as in insulation resistance, should i remove the line from the fittings and ir or should i test l and n to earth at 250V and if ok test at 500V?
As i say i am not sure what to do i have never tested a circuit with a pir and the circuits i normally test have a max of 1 florescent so i normally just remove line from fitting.
Any ideas what is best?
