Discuss texecom help!!!!!!!!!!!!!!!!! in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
trying to config a texecom 64w wireless system
front door contact
ground hall PIR
groud hall RKP
3x other ground hall PIRs
1x 1st floor landing PIR
the zones and attributes are giving me a f****** headache
my thinking
front D/C- entry/exit 1 with access and guard
ground hall PIR- guard access with entry/exit 2
the other 3 ground floor PIRS- guard with guard
the 1st floor PIR- guard with part 1 omit
full arms works fine
part arm bedtime 1- i want the 1st floor to not be active- ground hall to be my entry timer and all other ground floor to be instant
why using the above does the 1st floor activate the alarm when part alarmed and the ground hall PIR not activate the timer to unset it
cheers
Think your confusing setting up different areas with setting up part arms. Have you set up what zones are included in the part arms? Are you using Wintex or doing it via the RKP? If on RKP go to zone setup and press the part button. Press omit to look at/adust zones included in part arm 1, chime for part arm 2, part for part arm 3. Use the scroll buttons to look through the zones. Press the no button to toggle between on and off for each zone. Hope that helps.
Im a DIY user of Texecom, so test to make sure this meets your requirements, but i do a lot of Premier Elites at weekends :)
You want everything in area A, secondary areas aren't worth it on a normal setup unless its got a separate garage.
Front Door:
Entry/Exit 1
Area A
Front Hall PIR assuming this will be triggered between opening front door and disarming at the RKP and will be triggered when coming down in the morning after night part arm:
Guard Access
Access
Entry/Exit 2
Area A
Landing PIR Upstairs (off during night part arm):
Guard
Ommittable
Part 1 Omit (makes it ignored when part set 1 is set for bed time)
Area A
All other detectors:
Guard
Area A
It may be worth putting ommittable on all zones, depends on wether you want to be able to set the system with omits or not
If you are doing this at the RKP, buy a lead and do it in WinTex or get the SmartCom and do it over that.
Hope this helps
Brian
Only if they eat on command I know of a couple of people who lost their dogs because of poisoned meat put through the letter box by the thieves then they broke in once the dog keeled over
I’ve got round that problem. I don’t have a letter box and only feed my dogs on burglars. :D
Reply to texecom help!!!!!!!!!!!!!!!!! in the UK Electrical Forum area at ElectriciansForums.net
My Veritas R8 Excel panel recently developed a power fault and I have replaced the entire unit and reprogrammed it. I can part set the alarm when...
This isn't really an electrical issue as such but I know you guys are pretty tech savvy and familiar with all the latest and greatest...
Hi everyone We have a little problem with a heating system on one of the projects (quite big house in south Kensington) and we are looking for...
I need a fire alarm installing in a house that was converted into flats 30 years ago. It comprises 3 units. Ground floor and basement maisonette...
TLDR: is there a legal requirement to have a landlords supply to power an L2 alarm system? Mornin'. Non-electrician, under the cosh from an iffy...
