P
Prince
I have a fundamental question about the current
My question is: why after hitting the protons of a resistor and thus reducing the voltage and the speed of electrons; (voltage is the distance between the electrons which the distance is smaller than the balance between two electrons which do not affect each other at all) the current (the amount of electrons passing by a section of cable in one second in coulomb) does not reduce? Cause the number of electrons passing by a section of cable in one second with a reduced speed should also get reduced.
Thanks in advance
Thanks in advance
