I'm not sure I just put the part no in but it is three module wide so I suspect the new style won't fit.Same fitment as current starbreaker, surely?
First link I saw was screwfix. Oddly enough you can buy one from them in a board, for less than they sell them individually.
Newer units are all two wide, but busbar spacing would surely allow one to be fitted with a blank?I'm not sure I just put the part no in but it is three module wide so I suspect the new style won't fit.
Mcbs and rcbos are still compatible you can see I have newer mcbs in mine the originals were broken. A two module wouldn't fit as the busbar is fixed with socket points to plug in, one picks up the non rcd busbar the other to the outgoing rcd side there is nothing inbetween.Newer units are all two wide, but busbar spacing would surely allow one to be fitted with a blank?
Just curious to know if starbreaker compatibility has remained unchanged over the years.
Tripping for no reason could have been a dying word or message, maybe?Without a doubt. Strangely it randomly tripped back in the summer, switched it back on never tripped again maybe that was its dying breath.
Of course. I was picturing a solid busbar, which obviously isn't going to be found in a split board.Mcbs and rcbos are still compatible you can see I have newer mcbs in mine the originals were broken. A two module wouldn't fit as the busbar is fixed with socket points to plug in, one picks up the non rcd busbar the other to the outgoing rcd side there is nothing inbetween.
Most of the time and this goes for any tester it is the switch contacts that go bad first. It is usually dirty or corroded contact to the power on circuit.I wish I could figure out why this one doesn’t work. It was a great tester and the first “expensive” one I ever owned!
No signs of life at all, nothing screamingly obvious I could see wrong, so probably beyond me to fix!
Failing that, a blanket change of all 12 electrolytic capacitors might pay dividends.Most of the time and this goes for any tester it is the switch contacts that go bad first. It is usually dirty or corroded contact to the power on circuit.
I've cleaned all the switch contacts, still zilch.Failing that, a blanket change of all 12 electrolytic capacitors might pay dividends.
Thanks for some reason I read your post as “charge”not “change”. Makes sense now! CheersUnsolder the old ones, and fit good quality new ones of the same voltage and capacitance They're not expensive.
This doesn't look to be a circuit where the electrolytics are as stressed as in some, but they do have a limited life, and a blanket replacement is often easier than careful independent testing of each one.
Have you checked that little fuse if there’s no life at all?
Oh no… you can’t… your tester’s bust.
