This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
Simon47
Supporter
V.Nearly Esteemed
I'm sure it's a common requirement across church halls/village halls/etc. , but a search didn't throw up anything particularly useful.
Our church hall isn't used all that much - at the moment we're not taking general booking because we just don't have the volunteers with time (and health) to make it work. The heating has what I assume are the original control from when it was built in the 70s - a basic timer in the boiler room, and a mechanical thermostat in the hall. We're used to just turning the stat up when we go in, and turning it down when we leave. Occasionally, someone will forget to turn it down - but fortunately, it's a small building, built to (relatively) modern standards, so doesn't empty the oil tank too quickly. It also means we don't need to worry about putting in on hours before people go it as it warms up quite quickly.
I know there are things like TIME:O:STAT Landlord Thermostats and Calendar Thermostats, but they're way overkill (and expensive) for our needs. Before I cobble something together, does anyone know of anything simple ? I had in mind a simple "press for heating" which triggers a period of heating (with optional user set temperature), and then reverts to a background/anti-frost setting. To DIY it I'd just use a standard stat that everyone understands, a tamperproof low level stat, and a delay off pushbutton (like used for communal hallways) set to (say) an hour. Optional smaller button to reset if leaving before it's gone off on it's own.
Push button, heating comes on, after a while, it goes off again. Press button any time to extend.
Any ideas ?
I like your simple design. I suggest you use a clockwork runback timer with a sturdy knob and clear time duration scale. I think this would suit ‘all ages and dexterity’ and is obvious how to use with a suitable sign on its purpose. And a 230V ac mains led indicator to show on perhaps: One like this perhaps:
Does your Church have wifi? If so then I have fitted a few of these and found them to be excellent.
You can set timers for different days or just switch it on remotely before you go and turn it off at home if you forget.
Yeah, I know there's a lot of that sort of thing - yes we have WiFi. The remote access is attractive, but there's no way I could let our users loose with something like that :rolleyes: Also lacks the automatic "whatever you do, it turns itself off again after <some period>".
Also, as a matter of principle I avoid Amazon unless it really is the only option, and I also avoid devices that are reliant on "someone else's computer" (a.k.a. "the cloud".)
