Not strictly non compliance or a safety issue, but if the rcd went in the middle of a performance you wouldn't have any stage lighting at all, whereas if each socket (or better still each dimmer rack) were protected you'd still have some lighting so the show could go on.
Agree...TBH I cant recall whether it was an upgrade or a failure/damage that resulted in the job. I'm pretty sure we would have suggested RCBO's at the time,but likely this would have been a cost issue. Either way an RCD tripping could very quickly be sorted by unplugging the equipment from the 63a sockets so hardly a major concern.
Thanks for all the input guys.
But was that regulation in force 10 years ago?? Seems to have been a very long time before someone picks this RCD problem up!! To be honest, i'm not that well up on Theate lighting regulations, or whether they even apply in full, on/to a schools small hall stage??
True, 10 years ago it would have been to 16th edition, where it seemed you could put everything on one RCD, and unless you were going to use equipment outdoors or in a bathroom there was no requirement for RCD protection at all. As someone mentioned in another thread there's no requirement to upgrade to the latest regs, which seems to be this guy's problem.
I remember when I was at school (bit more than 10 years ago) we had a hard-wired dimmer pack on the wall with 4 RCCBs built into it, so if one went you'd still have the other 18 channels. Again, not a requirement, but additional protection.
