E
Engineer54
Now explain to me why there is nothing wrong with it? I dont quite see it?
If you have 2x cables capable of 30a each, running a 50 a load, and one leg fails, you end up with one cable running 50a thats only rated to 30a?
I think you would have to explain to me why would one leg fail?? Running ''Parallel'' supplies is standard practice, it can increase current carrying abilities, reduce volt drop, reduce labour costs and in many circumstances, reduce the overall cost of the installation over using a far larger sized single cable!!
Most of the supplies feeding our main switch boards and most sub switchboards on this and every other project i've ever worked on, will use parallel supplies, and i'm not talking of just 2 parallel cables but several per phase & N etc!!! Your talking about a couple of cables supplying 50A, and i'm talking of several cables supplying 3500A!!! Now think about the size of a single cable supplying that sort of load, ...doesn't bare thinking about does it?? ...lol!!!!
Standard Practice as i stated before!!!
