E
Engineer54
Yes at the minute there is a brick built cupboard to which the supply is being put to, this is where the isolation points for each of the 3 buildings will be. Buildings not erected yet but plans signed off. Again I am yet to see this, as I have only been described this over a phone call! I believe 2 will be dwellings and the other a workshop!
is there a requirement for the switch fuses to be double pole?
As far as the switch side of the Switch Fuse YES!! But then they all come as standard in that arrangement!!
I would think you are referring to the neutral being in contact first when the switch is closed as it makes sense not to have live conductors without the neutral (yep I know the neutral is live too) attached. And the neutral is the last contact to be broken when the switch is opened for the same reason. So in both cases the neutral is always connected when the 3 phases are connected.
