Discuss Torque Screwdriver..... in the UK Electrical Forum area at ElectriciansForums.net
L
LankyWill
My elbow is out of calibration and i would like to use a torque screwdriver instead, its something ive been putting off but i have finally caved.
What torque screwdriver is everyone using?
A little review would also be helpful
I use the Wera Kraftform torque set.
Yeah I really want one for final fuse board checks so that I can prove they are tight. I’m not a fan of the interchangeable blades I prefer separate screwdrivers if I’m honest. Just want to cover my bases..
I know what you're saying but with a torque screwdriver you "know" without doubt that you've followed the manufacturer's instructions to the letter (or number).
i suppose on more sensitive equipment where there is a chance of snapping the head of the screw off the tiny terminals,
for board swaps i use my drill on 3rd torque setting to hold in place before finishing off with manual driver
do see alot of snapped lighting circuit neutrals where someone has screwed right through the conductors, same with earths
human sense of touch is pretty amazing, put a tiny bit of grit on a flat surface, run your finger over it and youll feel it
I have a draper one that i bought last year after the scum broke into my old van and stole a load of kit. had to get one at last minute and it was the only one in stock at the time. does the job, dont use it too much in all honesty but cant fault it. nice and easy to adjust too.
I got one of those whia
https://media.NoLinkingToThis/is/image//ae235?src=ae235/2581K_P&$prodImageMedium$
sets, the bits can fit in the teeny whiny terminals, well not all of em!
I'd also recommend getting some of those 'Plusminus/Pozidrive' SL/PZ1 & 2, if the set doesn't contain them.
After looking at the extortionate prices for what is in essence a glorified screwdriver i think i might stick with the trusted technique of swear tight. I have thankfully never had a connection come loose or caused arcing due to a loose connection so im going to give it a miss.
Seems like another scam within the industry in which scare mongering is used, thanks for the input guys but im being a tight git atm.
Reply to Torque Screwdriver..... in the UK Electrical Forum area at ElectriciansForums.net
Long time no see and I hope you're all doing well. I see that torque screwdrivers have become the height of fashion in the UK over the last...
9K
Not that I've ever used one, but I have been known to mess around with torque wrench's and cylinder heads in my younger days! Torque wrenches do...
Hi All. Hoping for some advice please. I've severe arthritis in the hands (all three :flushed:) A large dollop of osteoarthritis but I'm also...
Hey everyone, working on a new build house and outside garage is wired up like this, however customer wants a Garage Consumer Unit instead of the...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
