Discuss total control in the UK Electrical Forum area at ElectriciansForums.net
the pict
Mentor
Just had a customer on the phone asking if I can connect up his total control heaters to its seperate consumer unit, I am going out to it this week, is this a dual tarriff set up as the term is something I thought was wet central heating, sorry if this is a bit vauge
Pict
storage heaters. have to stay till after midnight to Zs. happy days (or is it nights)
Total control is a form of storage heating. Works from a teleswitch with 3 outputs. One for the storage heaters, one for panel heaters, immersion boost and electric shower and one for off peak immersion. The customer may be requiring you to connect the 3 tails from the heating board into the triple pole isolator switch which is sometimes left by the electricity company.
Reply to total control in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys Got a job where property is set up with Honeywell evohome TRVs and controlled via central panel. They're having an extension done with...
My customer wants to be able to switch his heat pump (3.5kW) for his swimming pool on and off remotely, he also wants to be able to set times for...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Good day readers, if any,I am an old sparky, a very old sparky. I can remember old Faraday giving us lectures Wednesday evenings at evening...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
