Your own risk assessment dictates out of hours working
loads of H&S issues as ill be working around customers.
Don't see any other way than doing this outside normal shop hours, with the ambulance chasers your sure to get a customer looking for blame to make a claim because the lights went out and they tripped over something
It's not clear are you extending or diverting the existing circuits / cables to the new distribution position
Can't help but feel the price is a bit light but that is just a blind assessment not having seen the job
Joining out the circuits and moving them 20 mtrs to the new position is the easy bit, you can fit the new board and get all the circuits to the enclosure and din rail connectors near the existing board fairly easily, the change over will need to be out of hours, the testing of the circuits will be the challenge buddy, I would hazzard a guess at around £1500.00-£2,000.00 for the work, but it could be another 500-600 to test it all, 20 circuits under these circumstances going god knows where in the building may be a minefield, JMO, To give you a more accurate price which I don't mind doing I would need to know a little more about working heights, limitations regarding access to testing circuits etc.
Mike
