Discuss TPN DB small size to fit in meterbox or IP rated. in the UK Electrical Forum area at ElectriciansForums.net
Schneider also do weather proof dbs but not cheap.
Another way would be to install a normal 3ph db in a suitable ip rated enclosure.
Reply to TPN DB small size to fit in meterbox or IP rated. in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
We might need to have a small 3-phase DB in an industrial location that might be exposed to the elements occasionally, though normally it will be...
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
