If the neutral for the lighting circuit is removed from the board and then indicates live then there are only 2 real reasons for this.Either there is a light switched on or there is some other device on the circuit using power,eg smoke alarm or burglar alarm,but it beats me why the op would be doing what he is doing!
He obviously doesn't want to live much longer.
Matey, this is sooooooo basic its untrue.
Disconnect at cu and do simple dead tests using your MFT. YOU have done little or nothing to demonstrate you have done this or understand the reasoning for doing it so I'll give you the benefit of the doubt for ..........
As my signature bar says we are not mind readers and give as much information as possible - over to you.
matey get a grip n **** off
