^^ not sure I agree with your perhaps C3....
The most common time I see 2 cables is into lighting circuits.... Where a second cable goes to the bell transformer..... But it's still only 1 circuit!
I think the way @Westward was putting this he sees it a lot, like me where we may do more EICRs in factory's and large commercial installs where some of this stuff is absolutely lashed in and clotheslined all over the place, then they have piggy backed off an MCB and lashed the N &CPC in any old terminal. There is thousands of installations with rough work. Not all of this refers to neatly adding mrs jones a new light fitting under the stairs
Edit: There is no disputing the regs and evidence people have put forward but I will always continue to note it the same way I described in an earlier post
Well, well, well. Just look at the diagram below from an IEE Wiring Matters article. The diagram is taken from the IET Electricians Guide to the Building Regulations.
I think they have 2 radials in one MCB there or I could be seeing things.
Someone better notify the IET that their diagram does not comply with their regulations... :D
Right, thats put that one to bed. Now i'm off to bed...
Without the whole article the picture is a bit useless, for all we know the article could be using the picture to illustrate incorrect design.
Guys, there is clearly a conflict of opinions here which leads to hopefully a good debate and what the forum is about, but can we refrain from mocking comments and pictures, let's keep the discussion to a respectable level, mocking members be it seasoned or new is only going to promote replies that derail the thread and rubs everyone up the wrong way.
I would appreciate it if we all keep the debate on a professional and mature level and regardless who is right or wrong we refrain from lowering the tone with personal/character attacks on members.
Thanyou.
Reg 999.888.777.666.555.444.333.222.111- common sense. If you are a grown up and a practising electrician sometimes you have to make a judgement call. Dearest customer- here is my the reason for my C3 based on guidelines (i.e. BS7671) and my experience. I have given this a C3 code because of an isolation issue. The safety device is protecting the cable and humans/animals etc fire and electrocution. However, an improvement could be made by providing individual switching for these two circuits thus limiting inconvenience during a fault or maintenance. This is why we wire upstairs sockets/downtairs lights etc, to limit inconvenience. Be try best you can be, give the customer the option to have the safest and best setup that you can provide, but ultimately it's their decision. Explain that there are no spare ways so a new board would need to be fitted and this is how much it would cost. 90% of this particular topic is common sense, 10% common sense. Sometimes it's the other way round, most of the time it's somewhere in between- never forget that my pedigree chums!
But it's one circuit though....... isolate from the 1 MCB
But it's one circuit though....... isolate from the 1 MCB[/QUOTE
IMHO and without having the advantage of seeing the job I would suspect the sockets/lights are in different areas of the building. Otherwise, why not extend? I.e. The last fitting or socket on the first radial is a long way from the next. If the board is closer to the next fitting/socket, start from there again. There may also be access issues so yes, start a new radial. But it could possibly inconvenience the customer when you need to isolate and you lose both radials. So the existing installation is safe and works fine, but I can make it better.
I've not read all the posts, but surely the fact that the cables are in one MCB makes it one circuit by definition. If a house was wired with an upstairs lighting circuit, and a downstairs lighting circuit, if both legs go to 1 MCB it then has one lighting circuit. Maybe I'm wrong but that's how I interpret it.
