Discuss Type A or AC RCCD for a PC computer PSU? in the UK Electrical Forum area at ElectriciansForums.net
There are no logs for the solar other than a pictogram of output from Node Red and a sonoff_pow. There are three grid tied inverters feeding into a single phase but not the phase on which the trippy RCCD is located so I don't think the solar could be the source of the troubles. The replacement computer PSU arrived this morning ( great service from CCL Computers & PDP) so I will go ahead and fit that and then wait and see if there has been an improvement, if not I accept that it may be beyond my current capabilities to pursue the fault further with the limited equipment I have to hand. Thanks again
Reply to Type A or AC RCCD for a PC computer PSU? in the UK Electrical Forum area at ElectriciansForums.net
Hey, I want to use an old xbox 360 PSU- 12V 175W output- for my 12V sup pump (pump/air compressor). When I connected the PSU to the pump...
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
