G
Guest111
Reading posts about TT systems and earth rods lately,I,ve noticed that sometimes people have problems getting a low enough measurement,now I realise that not everyone is familiar with ufer earths so I thought I,d mention them,basically they were developed for the us military by a man named ufer who came up with the idea of encasing an earth rod in concrete when soil conditions were poor,is dry stoney soils.concrete is more conductive than these types of soil due to the higher alkalinity of the cement,also it tends to retain moisture for longer than the surrounding soil.the original ufer,s were just a hole about six inches diameter dug to the depth of the rod and filled with concrete,the rod being pushed into the middle and allowed to harden,later on the copper rod was replaced with a steel one after it was discovered that over a period of time the alkalinity of the concrete caused the copper to flake.Nowadays ufers are normally made by making use of the rebar in large concrete floors,the rebar being either double tied or welded together.However going back to the origin al method of digging a hole and encasing a standard rod in concrete,this may help some people if they find they are unable to drive a rod to a greater depth due to ground conditions.just thought I'd give this a mention.
