Discuss UK Voltages compatibility in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
Looking to purchase some commercial induction catering equipment which is rated at 380V and other items at 220V all at 50Hz will these operate on UK single & three phase circuits safely, correctly and without overheating issues, or will I have to introduce a step down transformer on the supply and if I do, will this adversely affect the existing electrical appliances, properties electrical circuitry?
i appreciate that the U.K. harmonised from 240V and 415V down to 230V and 400V with a -/+ percentage either side but I believe supply voltages still fluctuate across the U.K. hence the aforementioned question.
Status
Reply to UK Voltages compatibility in the UK Electrical Forum area at ElectriciansForums.net
Looking to purchase some commercial induction catering equipment which is rated at 380V and other items at 220V all at 50Hz will these operate on...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hi from the U.K. I have a U.S.A. 120VAC 60Hz ignition coil (made by Carlin Combustion, model 45000 proX… the data sheet says the high voltage...
What would I need to do to use this Chinese product in the UK...
Hi I know it sounds very grand but it really isn't - and, especially not seeing as there has been, and still is, no travel due to Covid for so...
