Re routed VPN? Can that diagram be re interpreted as wiring for a remote IED :D ? Although, saying that it does look like he’s already got one ;)
Why you guys talking about vpn's and ip's. I don't have a vpn because I can't afford and I am not from Syria. Real fun ha ha :p
And about the IED, it is what it is.
I think I'll need to change that wall socket to a double because this setup is driving myself a little bit mad too :D
It normally gives this information on the glass part of the bulb in a circle around the side or top , but I Guess you will never know now unless you get the CSI to reconstruct the bulb for you.:) , the confusion comes with the 24 volt ones because at a quick glance they look like 240 also years I've Known people to nick the bulbs from building sites which are 110 volt :D
Actually, long story short, especially this light bulb, I got it from an old abandoned school and it was of course used because I unscrewed it from the ceiling and that maybe it works :D Probably should test it before using!
Then that may be why. it could of been part of an emergency light system which would run at a lower voltage
Yeah maybe but it's was in room where there was a normal ceiling lamp and looked normal too me. I guess we'll never know. Thank you in taking part of this question. All of your answers were informative.
