O
optician
Hi,
Customer has a rewirable board, pme, and no main bonding.
I can run a 10mm bond to both water and gas(about 10 m), but customer
does not want trunking and due to Granite work tops and tiled walls, its
all a bit of a mare.
Can i bury the cable in plaster? it will be outside any zones.
Even going to the outside has its problems.
They have run the tails through the cavity and I'm worried as to exactly
where it is.
Whats wrong with a bit of trunking? help....
where it is.
