Discuss Update to 3 or 4 gang in the UK Electrical Forum area at ElectriciansForums.net
Hello to all, I have property with av2 gang meter socket, the lower unit was connected to the attic but is is now disconnected. What would be best approach to change from 2 gang to 3 or 4 gang meter socket?
I’m not sure that you will be able to find a 2,3,or 4 gang meter socket. Even if you could then you would have to draw a permit and set up a work order for the power company and when you are finished then it will need to be inspected before your power company will hook up your power.
Thanks you for your response, can I install a separate second 1 or 2 gang without disturbing power for the other meters?
Reply to Update to 3 or 4 gang in the UK Electrical Forum area at ElectriciansForums.net
Hi, just hoping for a bit of advice. When I travel abroad (Europe, predominantly Spain/Cyprus) I usually take a single travel adaptor and a UK 4...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
