- Reaction score
- 5,604
Evening all..
Just wanted a bit of advice about Earthing!! I'm not too sure whos responsibility the Earthing conductor is from the earth block to the cable sheath? It's 4mm and before I give out any certificate for a CU change I want to see 16mm. All other bonding and earthing needs upgrading as well but it was just this bit I was unsure about as I thought maybe its the DNO's field?
Cheers..
Cheers..
