Discuss Vacuum Cleaner Recommendations. in the Electrical Tools and Products area at ElectriciansForums.net
RDB85
Trainee
I’m looking to buy a hoover for work. As I am not a fan of using customers due to them being rather expensive. Any recommendations as to what to buy?
general use a Henry. if tou'redoing a lot of chasing with a wall chaser, there are more powerful ones. some even switch on auto when you start the chaser,but a Henry will be good if you're notfussed about a bit of dust on mrs. coggins' shagpile.
I have the nilfisk. I've had it for around a year now and I am very happy with it. Its a vacuum cleaner/dust extractor so if you just need a vacuum cleaner then perhaps the Henry would be better as I expect it is cheaper and lighter. Although I didn't find the Nilfisk that expensive.
I did look at a Nilfisk. I found this one on screwfix which looks to be a good buy tbh:
https://www.NoLinkingToThis/p/nilfisk-vp100-880w-10ltr-dry-vacuum-cleaner-230v/633ht
I’ve used Numatic Hoovers before. They are excellent. It also helps that you can buy all the replacement parts and that they are easy to fix when they do go wrong.
https://www.NoLinkingToThis/p/nilfisk-aero-26-21-pc-1250w-25ltr-wet-dry-vacuum-cleaner-240v/66972
I got this but was a lot cheaper then (Still from Screwfix) . I wanted a wet ability as you never ever know when you might need it !! The filter has lasted me 3 years of abuse .I really clean it out every month with a brush and compressed air . Its a bloody good unit ! I only use my Festool when i am using my Festool tools for wood /dust extraction etc . It would be useless as a site hoover
Reply to Vacuum Cleaner Recommendations. in the Electrical Tools and Products area at ElectriciansForums.net
Any recommendations for a decent prices dustless dust extractor. I have just brought the metabo wall chaser but I don’t want pay 4-5 hundred quid...
Hi, I currently have a Megger 1730 v1 which is fine for all functions except the 2 wire (L-E) no trip loop test, (no 3 wire loop test on my 1730)...
Hi all, Firstly I am new to the forum, so will start by saying hi. I work as an electricians mate, and am joining the forum to gain experience...
I’m building a vacuum exposure unit…..and so I’m sourcing a 24v transformer to match load of 24v timer…….timer will control qty 10 x 18 watt...
Hi ..right where do i start ..ill do the best i can !! i have an extension lead and in it are plugged a fridge , a separate small freezer ...
