- Reaction score
- 1,665
Right so after weeks of my 2.0ltr vivaro randomly losing power and going into limp home mode it has now decided that it's going to do it all the time! So tried the usual things like new filters, map, maf, boost pressure sensors with no luck, ok I will check the egr, throttle body and turbo to see if they are the issue but alas no, all were clean and working as they should. Also should point out that there are no fault codes on the engine.
So I'm thinking either a wiring fault or some other sensor with issues that I haven't already changed!?
Has anyone had a similar issue with thIs? Even on a Renault or Nissan van as they are all the same gear! They are popular vans with several problems I find on the web, but it has been a good Van with no problems till now!
Many thanks for any help
Sparkysy
Sparkysy
