Discuss Views on consumer units in the Industrial Electricians' Talk area at ElectriciansForums.net
I like using Crabtree. Used MK and they are ok but feel flimsy to me. MEM I don't like - poor build quality and covers which do not go on too easily!
contactum are made from very flimsy and thin plastic, sharp bits of plastic that cut you every time you put your hands ant where near inside them. maybe I just had a bad one?
i do tend to fit wylex, but i was just seeing if theres a more popular one out there. Mainly because wylex mcb's/rcbo's are easy to get hold of where i am.
Tend to use Hager or Wylex but fitted a Proteus :D not so long ago that the customer had bought. Was pleasantly surprised, easy to fit and quite a bit of room. Like so many other things you tend to go with what you are used to, you get familiar with certain boards and you know what the weaknesses are and know the way round them.
wylex, crabtree both good , but i,ll also spend a bit more time fitting the cheaper ones like ~ marbo , volex , square d ect, if it means more cash in my pocket :)
Reply to Views on consumer units in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
I want to know if my consumer unit (together with the digital meter) which is in a special metal container let into an outside wall near the...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
Hi, NAPIT report was carried out due to flood, all kitchen appliances, wall/light switches, fire/heaters etc need replacing. The electrician...
HI My flat just failed the EICR because there is no RCD in the consumer unit. There is no space for a new RCD as the consumer unit is full. Do I...
