a 2-dissimilar metal flexion alloy thermal cut out with a reset press by the looks of it, you might want to get a couple of nice new ones off ebay, about £4 each as far as I remember....check the old fan over, if the new one is there then just fit it and bin the old one...have a think about if the cut out can be fitted to the new casing, stick a new cutout there if it will rivet on, if the casing is awkward then as it's a throwaway part, you could get someone to put 2 tiny spots on the fixing plate(the metal flange on the cut out) to fix it to the casing....with some kind of thin welding wire... will take them 20 seconds to do it and will probably only take a fiver, if they will even ask for anything...
if you need any help to find the right cutout then drop me a PM
