M
Mike Watters
a periodic report reports that a water heater is not allowed in zone one. the 2.5 supply cable is clipped direct going into the bottom of the heaters. the heaters store more than 15 litres. regs wise whats the deal. how do i make them comply without moving them. rcd yes but what else? thanks
If the equipment is fixed, permanently connected and suitable for zone 1 (according to the manufacturers instructions) then there is no reason to change anything, is this not the case?
Reg 701.55
What type heater mate? Im struggling to think of any water heated thats rated for zone one.
I would have thought the regs would be refering to a shower when it mentions water heating device.
just a big vented cylinder type tank with an element inside i guess
. more than 15 litres, dif rules for heaters with less than 15 litres. tanx
box it in :)
usually these water heaters are non IP rated where the cover for the element is
Box it in and just give access to suit its access needs, ie service maintenance = Screw
