• wirepuller: The only concern with main bonding is on incoming extraneous conductive parts. Bond at the point entry or near as practical and it is dealt with. What happens to the pipework beyond that point is irrelevant,as within the fabric of the building it can no longer pick up an external earth potential.
    Further to the above, which is probably fine for the majority of houses and bungalows, but in multi dwelling blocks of flats, extraneous earths can be picked up quite easily from the fabric of the building, depending on the type of construction and the materials used for construction and the service pipework systems etc...
    Which is another reason why you should ALWAYS test as best you can, (not always as easy as it sounds) and not just assume one way or the other!!
  • Further to the above, which is probably fine for the majority of houses and bungalows, but in multi dwelling blocks of flats, extraneous earths can be picked up quite easily from the fabric of the building, depending on the type of construction and the materials used for construction and the service pipework systems etc...
Agree,bonding in those circumstances could be more complex if non-continuous pipework within the flat was in contact with structural steel,it's not a situation likely to be encounted very often though.
