Hello
This is first of what will be many posts on here, what I would like to know iswhat am I qualified to do and what jobs should I be applying for ??
I have passed my 2365 level 2 & 3, passed the 17[SUP]th[/SUP]edition and also the sad old PAT testing, I don’t my 2395 last night and havethe 2394 tonight but to be honest I think I bombed it and will end up resittingthat at a later date.
So after so much money spent am I employable ??
I would like to get into re-newable energy and my 15years as a general builder would help with that I hope.
Many thanks in advance.
chris
That doesn't make any sense to me at all!!
Do you mean you sat the 2395 last night and the 2394 tonight?? Which still doesn't make any sense either!
What are you like with containment, armoured cables and the like? Is all your experience domestic or have you done any commercial installs? What sort of work are you looking to get into?
if you've no experience at all in testing and Certs then you've more than likely just wasted the money you've spent on your 94 and 95, I'd learn to walk before you get to running
PMSL ... another first class impression from one of our highly educated respected members How very rude!!! (re' Tonys post)
TBH ... he in a good mood )
I think what he was getting at is your really want to be doing a few good years where you understand the concepts of safety of single phase supplies as well as understand the calcs and install methods as oppose to your experience of having all the design etc done for you and your just been an electricians mate/labourer.
Once you have a few good years under your belt of designing your own wiring systems on paper and putting them into practice without relying on a common fall back of rules of thumb often used in domestic then i would say you can step up another rung on the ladder and work with someone who has experience in 3ph systems and further your knowledge..
40 or 16 makes no difference in the eyes of competence which is what you need to be and having only experience labouring for an Electrician at most will mean you now need to get experience now as a qualified person to become competent. Their are no shortcuts to competence.
You dont know me to say that, I am 40 years old not 16????
All I said is I need to work on 3 phase to get use to it having only bashed houses.. how rude you are.
No he isn't, Tony with his experience has probably forgotten more than you will ever learn.
You asked a question and he gave you his answer.
Why take the hump when he gave you a truthful answer.
Mate Tony tells it as it is without the frills. You asked a question and got an answer.
The fact you set off by stating you’re a builder hasn’t endeared you to me for a start. Having no experience didn’t help. Stating you’ve been doing electrical work for years defiantly didn’t help your cause, this forum is full of topics on Bob the builders lash ups.
As to what you should be applying for, how about a brick layer. Leave the electrical work to those that have trained properly for it.
So do you have ambitions of going in to industrial work? If you have then it’s open season.
I don't understand you people, you always have a moan when someone new comes into the trade... its like you have something to be scared about ????
plus without builders you would not have a building to put electrics into so get off the soapbox and stop moaning..
what a waste of time this forum is with people like you here.
Don't worry about this grumpy lot on here, I mean who really cares if someone's kid dies from an electric shock or fire, you just throw those cables in as you see fit.
you lot automatically think I just chucked it all in, well I did follow everything in the OSG so sod off the lot of you. heaven forbid someone needing help for real..
