Discuss what reference method? in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
T/E clipped direct to brick. however, kingspan backed board is to be fitted so insulation direct onto cable. my thoughts are 102 as cable is touching wall, but not the inner board as described in BS7671.
Reply to what reference method? in the UK Electrical Forum area at ElectriciansForums.net
Hi All I wanted to ask a question about the reference method. Passing wiring through holes made at 0.2-0.4 of the joist span. The cables passes...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Hi All I would appreciate some help with a few questions here regarding cables sizing, I'm using the latest 18th edition, amendment 2. Q1...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
I'm looking at putting up & down lights onto a solid brick wall (1900 semi detached house) What's best way practically and aesthetically to...
