Discuss what supply is this? in the Australia area at ElectriciansForums.net
S
seppe
only recently qulifide and came across this then pricing a job looks to me like a TN-C-S with the earths coming from cut out but was unsure due to 2 cables going in at the bottom.
Its a TN-C-S (PME) System. the cutout have been changed to suit. It does state on your photo that its a PME but if you want to double check contact the supplier.
Depending on your planned work (i.e. if your thinking of a rewire) you may need to contact the supplier anyway to uprate the fuse?
TN-C-S Drawing Attached.
PS: Interesting to see the difference in the colour of the L & N meter tails!
bl@@dy hell, Nothing wrong with your eye sight :)
This is TN-C-S the 2 cables are one in and one out and the other does link to another property, this was common practice by the Electricity Boards to save running two cables to properties where the cutouts where in the same location i.e. back to back on adjoining walls. ( Ex Electricity Board sparky )
Thanks TOG for your knowledge have seen similar my self specially in towns, terraced houses other comments were spot on .
Reply to what supply is this? in the Australia area at ElectriciansForums.net
I've been installing Type 2 SPDs in consumer units for several years now, and they always come as a pair, connected across L & E, and across N &...
Might be a silly question, but can a tt supply come into a property via underground . This property in question, has no overhead cables...
Evening Chaps As can be seen in the attached photo , the incoming supply cable has a Earth soldered to the outer sheath of the cable suggesting...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
