Discuss What's the trick in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Really dumb question!
Is there a trick to removing these downlights, this feels like it's built into the plaster board, normally I just twist, wiggle and pull down and the springs go back and down drops the light. This one just pulls the plaster down. What am I missing?
Thanks,
Martin
As above , super strong spring in a 69mm hole instead of a 72mm for example. Try and pull it down evenly and compress one side of the spring with a fine wood chisel or the like whilst tipping it over as you compress it to slide it down. It is hard to get it out without damage though.
as long as you can get some of the spring exposed you can always use a mutli tool to cut the arms free and then put some new ones on.
I have also used a multi tool blade to cut in under the outer rim freeing all the plaster, paint etc, you can then usually get a bit of play on them and twist a bit.
It may not be the spring type, a few have two blades and are secured into the ceiling by twisting clockwise. To remove simply twist it anticlockwise, (I think it's that way round!) if it is that type you'll know because it'll pop out really easily whereas no amount of pulling will drop it.
Reply to What's the trick in the UK Electrical Forum area at ElectriciansForums.net
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
I am never quite sure if I am doing too little or too much when someone has a flood and I am called in. The most recent example is a chap has had...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
