SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Discuss What’s your countries Max Zs Values? in the Electrical Forum area at ElectriciansForums.net
Wetroom Store - Network Wetroom Suppliers
pc1966
What is interesting there is they are higher then BS 18th and the method generally used here.
For example, a 32A B-curve MCB here has the "instantaneous" magnetic trip at 3-5 * In so 96-160A and we would assume the worst-case, so to hit the sub-0.4s time you need Zs to be below 230V / 160A = 1.44 ohms. This is already below your 1.8 by a noticeable amount!
Next we assume you have to meet this at lower limit of UK supply voltage specification (95% of 230V) and when the cables are hot (so if measured cold, 80% of worst-case resistance) leading to a verification value on cold testing of:
1.44 * 0.95 * 0.8 = 1.09 ohm (given in the IET's On-Site Guide Table B6 as 1.1 ohm)
So Aus/Nz are 64% more optimistic!
telectrix
Mentor
australians are more sensible. when do we run cables @ 70deg.c? and when is our voltage down to 216V? load of crap. just anothe reason for IET to bring out a new edition to increase their pension funds at our expense.
Instyle LED Lighting Specialists UK
Reply to What’s your countries Max Zs Values? in the Electrical Forum area at ElectriciansForums.net
Top Bottom
