Discuss When wiring Spots, why have some stayed permanently on? in the DIY Electrical Advice area at ElectriciansForums.net
Status
Not open for further replies.
PowerCut
I've wired up my spots however the main light [the one that was once a ceiling rose] works as intended with the light switch, but the rest are permanently on?
What have I done wrong?
The spots do not have In and Out terminals as part of the fitting, only a blue and brown connector block.
It sounds like you have fed the other lights from a permanent live rather than a switched live.
Do any of the wires at the rose have sleeving on them?
Can you post a photo of the rose wiring.
Can you keep this to your other thread please.
Status
Reply to When wiring Spots, why have some stayed permanently on? in the DIY Electrical Advice area at ElectriciansForums.net
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
