I got a super rod mega set, have a £25 blue set as well, but the Mega set with all its accessories means it has far more uses and should in theory save time than using the cheaper blue rods.
[QUOTE="I have however twisted a rod apart by using it in a battery drill to try and get past a particular difficult beam.[/QUOTE]
I love this! I've never used a cable-rod in a drill myself, however I fully understand your reasoning - if the rod spins fast-enough, it will bend through the centrifugal-forces, hopefully enough to avoid something blocking it's path. It's likely that I will try this soon!
I've also found that taping a 6mm CSA wire to the leading-end of the rod (while rotating and gently pushing) can guide the rod through tight-spots.
Also, if you tape several-loops of sleeving to the leading-end of the rod, you can pull-it through tight-spots by combining it with another rod with a hook on the other-end.
..........Not sure I'm into this option, having burnt myself on a chuck recently, never mind adiabatic equation ..friction comes to mind ! , For thermal damage !
Respectfully Static Zap, this isn't my quote, rather a quote I replied to. I think the quote-function malfunctioned for some reason which I'm happy to edit if pointed-out.
Also, never-mind burning yourself on the chuck! After I drilling repeatedly through red-brick, I accidentally touched the red-hot bit with my arm which hurt like mad, leaving a permanent burn-scar!
