H
haptism
Hi hope someone can help, i need to record the protective device on a MWC and not sure which to enter.
I have removed an old bathroom heater on a 20A radial and rerouted cabling to feed an RCD FCU, the load side of which feeds into the bathroom serving towel rail with a local DP (20A) switch.
On the MWC for protective device, should I enter the 20A fuse serving the entire circuit, or the 3A 1361 within the RCD; or should I write out two seperate certs for each leg. Thanks
