Search the forum,
Discuss Which source drive the star delta contactor in the Australia area at ElectriciansForums.net
L
layzbass
Hi sorry for my newbie question, I've a question about a star delta starter. What exactly drive the mechanical contact in contactor, is't AC 240/220V separate source from L1,L2,L3? thanks.
a contactor is a large relay. It has an electric magnet inside it, called a coil. the connections for this are usually labelled as A1 and A2.
when the coil is energised, it will pull the contactor in, and operate either normally open (NO) or normally closed (NC) contacts. The coil can be fed from the same source as the contactor, or from a different MCB, or as is often the case, through an ELV transformer.
Please find the picture above,the D.O.L diagram. Anyone can tell me how the auxiliary NO working base on the schematic diagram. Tq
Reply to Which source drive the star delta contactor in the Australia area at ElectriciansForums.net
Heeelp! I have an 11kW/21A motor which is attached to a hydraulic power pack. I have replaced the old panels with new, using the same star delta...
Hi Guys, sorry if posting in the wrong section. I am due to start 2391-52 course soon, and there seems to be from what I have found out, a 3 phase...
Hi there, I got a call to a job, table saw (wood) tripping C/B straight away. 4kW motor on Star Delta Starter. So I get to the job, after some...
Hi I got called out to a faulty star delta starter on an old Stenner band saw Monday (was getting stuck in star and blow fuses) - So I ordered a...
5K
