Discuss Why do T5 Tubes in Emergency Luminaires Wear Out? in the UK Electrical Forum area at ElectriciansForums.net
E
Eschatonic
LO All,
The title says it all really.
I've just tested a shed load of 11 year old emergency lights and effectively all of them have failed or failing tubes.
Since the most that they should have been on is 11 x 1 hour and 1 x 3 hours per year why would a 5000 hour lamp fail?
After 11 years I expect all of the NiCd battery packs to be shot but the lamps surprised me.
Any ideas amigos?
old age? seriously, are thes EMs maintained? if so the lamp life will be weeks instead of tears.
If it's defo the tubes themselves then I can only presume a bad batch was manufactured. Maybe gases have slowly leaked out over time. Dunno..
Personally I wouldn't waste any Brain cells thinking about them.
Just change them for LED fittings and expect to change those in 10 years as well.
Nowadays nothing lasts, let alone lasts forever.
If it's definitely the tubes, i.e. new tubes work fine in the existing fittings, then I suspect faulty tube manufacture as tubes don't really have a shelf life and should run for decades of periodic tests. Tubes running on cheap low power inverters as in basic emergency fittings may have reduced lifespan but not as low as 150 hours.
I have seen sub-standard T5 tubes of two no-name brands supplied with 12V inverter fittings that failed after a short period, maybe 100 hours. They gave out a perfectly good light at first and would not have aroused suspicion in an emergency application for some years, but the ends began to blacken and then refused to strike. There was nothing wrong with the fittings as I replaced them with Sylvania tubes that have lasted for many years and still going strong.
Reply to Why do T5 Tubes in Emergency Luminaires Wear Out? in the UK Electrical Forum area at ElectriciansForums.net
A slight rant. Having just finished a spate of commercial EICRs I really can't understand why we tolerate these wretched things: 1 - I now expect...
The lighting on my boat includes about thirty T5 8W 12" tubes in conventional 12V fittings of good make (mainly Labcraft) with HF inverters...
Hi all, This is kind of prompted by the existing emergency lighting thread, but is subtly different. I do some work for a charity in Cardiff and...
R
21st Feb 2014 Today I had one of the weirdest faults I’ve ever come across. My conclusion to some may sound bizarre but from what I can see...
Robospark
R
M
To start off I will introduce all the exams you will have to take for this course, I haven't passed it yet but I know what they want from you.This...
18K
